Engine Charge Cooling Gain, how is it applied in the model?
Hi Guys,
Im using a motec M150 and am trying to understand how the engine charge cooling gain is applied to engine charge temp model, and how ethanol affects it.
there is no way to set the latent heat of vapourisation of the fuel being used so I'm assuming it is an approximated model and you adjust this cooling value for the % of ethanol in the fuel.
is the resulting charge cooling gain a fixed offset from the sensor reading, so a gain of 13 degrees would mean inlet temp-13 would be the value used as final inlet charge temp or is the charge cooling value scaled by differences in lambda and IAT?
if anyone knows how this is calculated I'd like to learn more about it.
Alex
Alex
