CAN setup
Hi members,
our CAN actually work. But we spend much time to set it up how we want it.
Espacially the CAN's wich will be transmited with 100, 50 or 10 Hz.
There the CAN ID's are predefined and can not edited.
You also can't choose two or three CAN BUS to receive. (ECU Can Bus and ECU Can ID Base can just get one parameter)
Is there an easy way to setup the CAN in the tune?
Or is it just possible with changes in the build?
Malik
Malik
