Rich/lean lambda values during acceleration
Hi Members,
today we went to the test track for the first time with our car and we got some serious problems with our engine or application.
We used a applied map from the dyno to the car. We set for all loads lambda to 1. In very high load we set it to 0,9 or 0,85.
As we crank up the engine the lambda value was around 0,9. Also when the engine have optimal temperature.
What can be the reason for that?
All sensors are the same. The mapping and other settings are the same. No changes. No Trims or Compensations for Fuel wich would it change.
On the track we have instructed our driver to give high throttle shocks and hold them for a second. Then he should let out the throttle compelety and do it again for the whole track.
We heard many ignition fails. And the driver wasnt amused.
After this short stint we look at the loggings and notice lambda values from 0,9 to 3.
Look at the logging below.
I think it is normal when the throttle is pushed very fast to the maximum the lambda value will be leaner. But not from 0,9 to 3.
Also the lambda value wasnt hold the aim value of lambda 1 or 0,9. It is changing rapidly also when the throttle is even 100%.
We have looked on all other channels to search the reason for such a bad behaviour, but we didint found it.
Where should we search?
It seems the fuel enrichment by acceleration isnt active or to less.
Fuel enrichment by acceleration/deceleration on the M800 is an easy function, but how can we set up this by the M150?
Thanks for your help.
