Output and M150 fails
Hi members,
since yesterday we have got some serious connection problems with our m150 on the car.
At morging on the first connection everything works fine.
After a few minutes and changes in the setup the m1 slightly works slower and slower until it doesnt works.
When i reconnect it (disconnect the ethernet cable and battery supply) i couldnt send a package to the m1.
There is just the pop up window with the loading bar and the comment 'sendin system'
There is no CAN connected and just a few sensors. We just setup the drivetrain (shifting and clutch)
But the diagnostic of CAN 1 and 3 says
So after one hour without any action on the m1 and no battery connected the m1 worked again for a few minutes and so on.
This all just happens at the car. Not on the dyno. And on the dyno is CAN 1 used with a lot CAN traffic.
The other problem is that we couldnt send any output to the Half Bridge Output 7.
We send test outputs but no signal. We measured with a multimeter but nothing.
We also set it to a function (cooler fan 1) where we are sure that it will work but also no signal.
It seems that the Half Bridge Output 7 is death.
Is there any other method how we can check this befor we contact our deal?
Is there a function in the m1 to stopp any action on this output?
Thanks for your answers.
Malik
Malik
