M130 and VR abs wheel speed
Mon May 22, 2017 5:59 am
by Moorespeed
Can i use a 2 wire vr wheel speed sensor with my m130 and if so what input do i wire it as or to?
Re: M130 and VR abs wheel speed
Mon May 22, 2017 11:05 am
You need to supply switched 12V+ to the + pin on the sensor, and then from the - pin on the sensor you wire this to a UDig input, with a bridge through a 220 Ohm resistor to 0V.
This should give you a signal range between 1.6V and 3.6V, so use a Threshold of 2.5V and a Hysteresis value of 0.2V.
Mon May 29, 2017 5:33 am
by sphilips
can this also be done with the m800? I mean the 2 wire speedsensors wired to the digital inputs?
