m150 table fluttering
Wed Apr 26, 2017 8:33 am
by nwwil
when i connect my laptop to my ecu the map table starts to flutter, whats wrong
Re: m150 table fluttering
Wed Apr 26, 2017 10:15 am
I am presuming that you are meaning the Engine Efficiency table? Are you saying that the engine runs differently with the laptop connected versus not? Can you provide some logging showing this occurring please. Standard level 1 logging with all of the diagnostic channels logged will suffice.
Wed Apr 26, 2017 5:25 pm
by nwwil
it does it with out the engine running as its new build and have not started engine yet
Fri Apr 28, 2017 1:24 pm
Do you have any sensors connected to the M1 yet? What sort of range of fluttering are you seeing? 1~2 kPa, or 50+ kPa?
Sat Apr 29, 2017 9:22 pm
by nwwil
think i;v found the problem, i disconnected the ltc and its sorted, so i pulled the ground wire and put direct to ground and its still ok, so i hope thats sorted. thanks for your help
Mon May 01, 2017 2:01 pm
Which ground wire did you pull?
Tue May 02, 2017 7:28 am
by nwwil
the one out of the ltc
Tue May 02, 2017 9:40 am
by SprinterTRD
Sounds like you had the LTC ground connected to the 0V sensor pin on the ECU.
This will cause the problem because the 0V sensor pin on any ECU is not designed to handle the current when the LTC turns the lambda sensor heater on.
Basically you didn't follow the wiring diagram for the LTC!
