Failed to update the ECU
Hi members and users of M1XX,
I have problems with our M150.
I have allready use the search function, but there was no post about it.
I hope you can help me.
I would explain the steps what i allready have done at first.
1. Download the GPRP M150 Project at https://moteconline.motec.com.au/Project/ViewProject?PackageId=383&BackURL=https%3A%2F%2Fmoteconline.motec.com.au%2FProject%3Frand_token%3D63152219
2. Open it in M1 Build an configuered for our requirements (just a few things on 'Objects', numbers of axes some names. Nothing great.)
3. 'Build Fimreware an open in M1 Tune' - from Project to Package
4. There is/was no Error message or something else. Enything runs!
5. Configured the new builded Package in M1 Tune - Create Layouts, Set Inputs/Outputs, Calibrate Sensors, Add Tables. Just normal use.
6. Pluged the M150 (Hardware) on our engine on the test bench.
7. Pluged the Ethernet cable on my Laptop and connected with the ECU
8. Installed the License (downloaded from https://moteconline.motec.com.au/MyECULicence/GetECULicence)
9. Send the configured Package (from point 5) to the ECU M150
10. No ERROR messages, just one WARNING message ('Failed to configure ECU Data Acquisition' - I dont think that this will be a problem that prevents me to work with the M150?!)
AND NOW THE MAIN FAILURE
11. There is no signal of any sensor or something else. No Battery voltage. Nothing.
We have allready checked all Plugs.
There is a voltage of 14 V on the pin B13 and ground.
The Engine was running minutes ago (with the older ECU M800). All sensors have worked - no problems were detected.
12. When i type any value on any calibration or table and press enter there comes a popup-window with 'Failed to update the ECU - The ECU rejected the update, the local changes will be reverted'
I've also called our dealer in germany. He send me the ECU license to download it again to install it again.
I've done it, but the problem is still there.
Can you help me?
Thank for your posts.
Greating from germany, Malik
Can you help me?
