Fuel Pressure and TC setup
Hi
M130 ECU
Car Toyota Supra 2jzGTE
Package:
https://1drv.ms/u/s!Ao-FTTt3GMhrh-Nri7JRLckeU0yeDw
Fuel Pressure warning, what do you guys recommend?
I am running OE pressure ,
Fuel Pressure at Idle w/vacuum hose disconnected is 43psi ( 3.0 kgf/cm)
Fuel Pressure at Idle w/vacuum hose connected is 36psi (2.5 kgf/cm)
Traction Control
Light Resource used is Half Bridge output 2 , in test mode illuminates the engine light and the MIL (Red Triangle center guage) light,
How do you assign what light each warning uses?
The TC light resource in the drop down is Peak Hold Injector 7 (Engine light) , on start up my car illustrates the engine light for about 5-10 secs since I wired in the wheel speed sensors , I presume to indicate it is intialising the TC?
TC-- INVERT set to ON , what does this do? the Firmware Notes are not very clear
The TC toggle switch is set as the OEM button , but when I press the switch to toggle ON/OFF the ECU logs a minimum Voltage traslation error for a few secs, any help on how to set the voltage? or is this due to the input , Analogue Temperature Input 4 setup?
M130 ECU
Package:
Traction Control
