Is this a good idea?
Because I am broke, can I use Auxillary output 5 via a 'relay' the trigger the starter motor? I would be triggering vvia a CAN message.
Will get a PDM when I have the money, just looking for a short term CAN based solution.
TobyOctane wrote:We experienced that the problem could occur that the starter motor was staying on in some CAN communication error cases, which is fatal if you use overtuned aprilia engines. When using only motec equipment and a robust starter motor, this should be less of a problem.
