Auxiliary Outputs
I am using the M142 GPR-DI (latest version) package from motec online and would like to change the activation conditions for a switched auxiliary output.
Aux Outputs 1 and 2 can only be activated using MAP, and Aux Outputs 3 and 4 using TPS. I haven't been able to find anything to change this - I would like to set them to be activated by a 3d MAP with coolant temp and RPM. Even just changing it from MAP and TPS would be nice...
I did a search first and found this question has been asked before, but I couldn't find and answer.
http://motec.com.au/forum/viewtopic.php?f=53&t=2739&hilit=aux
http://motec.com.au/forum/viewtopic.php?f=53&t=2644&hilit=auxiliary
Am I missing something, or is this just the limitations of the software package I have?
Thanks,
plohl
Thanks,
plohl
