These are two faults that I would resolve, as they provide crucial information on the engines operation to the M1.
The Translation Minimum for the Inlet Manifold Pressure Sensor is caused by the voltage signal being received being below the range of the translation table, this means that the M1 is not receiving a valid Manifold Pressure value, and could be calculating the engines load incorrectly. This will also potentially effect the rest of the engines operating range if the whole of the scale is wrong.
The Throttle Position Sensor Diagnostic is caused by the 0% of the pedal not being set, this should be resolved as well as it can effect the engines idle operation, amongst other areas.
