M190 and PDM16 wiring loom and autosport plugs/pin
Postby uaeproz on Thu Sep 01, 2016 7:50 pm
Hi All,
I'm newbie here and I need your help with the subject. I'm in the process of buying M190 & PDM16.
I know the following:
-PDM 16 26 pin Autosport Mating connector A - 65040
-PDM 16 1 pin Autosport Mating connector B - 68093 (wire gauge #6 AWG) or 68094 (wire gauge #4 AWG). This is dependent on the wiring loom gauge (wiring loom AWG).
-PDM 16 8 Pin Autosport Mating Plug connector C - Deutsch AS616-08SN
-M190 Autosport 55 way Yellow Mating connector A - 65031
-M190 Autosport 26 way Red Mating connector B - 65034
-M190 Autosport 55 way Red Mating connector C - 68090
The question is for the Wiring loom - I wanna buy 5 wiring looms cut to fit and maybe there's a wiring loom that contains all or some of the above connectors but I'm unable to find it. Which ones are these? this could save me a lot.
I'd appreciate your help.
Thanks,
Abdulla
uaeproz
Re: M190 and PDM16 wiring loom and autosport plugs/pin
Postby adrian on Fri Sep 02, 2016 11:01 am
Customers that typically purchase these devices will customise their wiring specifically for their application and don't normally purchase generic cut to fit looms, hence we don't offer looms for the devices with Autosport connectors.
In saying that, a number of our dealers and members of this forum provide high quality motor sport wiring looms and would be able to make these looms for you.
Postby uaeproz on Fri Sep 02, 2016 6:22 pm
Thanks for the advice. I'll check with the local dealer if they are offering the same.
Much appreciated for the reply.
uaeproz
