M1 Tune unable to retrieve datalog
Postby bing on Mon Aug 08, 2016 7:08 am
I have a M1 Tune Beta 1.4.0.136 installed on new laptop.
I am not able to retrieve logged data.
Software will tune and open ecu.
Thanks,
Brian
bing
Re: M1 Tune unable to retrieve datalog
Postby Stephen Dean on Mon Aug 08, 2016 9:42 am
Hi Brian,
What errors are you receiving when you try and retrieve the logging? What Package are you using?
Postby bing on Tue Aug 09, 2016 9:59 am
When it get to Retrieving Logged data it just stop. I had same issue with Standard GPR-FT-86 package and one custom package made for 2008 Honda Civic from one of the dealer.
Thanks,
bing
Postby Stephen Dean on Tue Aug 09, 2016 10:59 am
Hi Bing,
Is there logging to be retrieved? Can you have a look at the Logging status channels as below.
If the Used value is 0%, then you will get the same error as you are showing.
Postby bing on Tue Aug 09, 2016 1:55 pm
I have 84% used..
bing
Postby Stephen Dean on Tue Aug 09, 2016 2:25 pm
Have you ever been able to download the data? With the directory that you are saving the data to, do you have the correct access to it to be able to write the files?
Postby bing on Wed Aug 10, 2016 2:46 am
Problem solve, it was the logged data image folder in different location.
Thanks for the help.
Brian
bing
