Get inj battery comp from an mtccal file
Postby Wolf_Tm250 on Thu Aug 04, 2016 7:13 pm
I'd need an injector's latency/batt values for an Mx00 ecu and I found there is an M1 mtccal file of the same injector:
how to extrapolate the values I need?
Wolf_Tm
Parma - Italy
Wolf_Tm250
Re: Get inj battery comp from an mtccal file
Postby Stephen Dean on Fri Aug 05, 2016 9:41 am
If you send an email to support @ motec.com.au with the part number for the injector, I can provide you with the correct values for the Mx00 ECU's. You shouldn't use the M1 Data for the Mx00 ECU's as we calculate the data differently.
Postby Wolf_Tm250 on Sat Aug 06, 2016 3:20 am
SDean wrote:Hi,
Email sent,
thanks for the support.
Wolf
Wolf_Tm
Parma - Italy
Wolf_Tm250
