DentGuy wrote:Does anyone from MoTeC have any insight on this feature? If it is something that will never be offered I may need to start looking into a partner package.
Im in the same boat hoping for this feature. I found this info on the R35 forum hopefully with part of the work done it could be implemented into the GPR package.
DarrenR, on 02 March 2014 - 02:56 PM, said:
When you're driving at a constant speed and press the button, the anti lag works for a rolling launch by retarding and/or cutting ignition while opening the throttle to let more air through. The cut and retard levels are set on 2 tables with throttle pedal and engine speed, so if setup correctly you can still modulate your speed with the pedal with the pedal altering the cut/retard to give you more or less torque. The throttle at this point is controlling the air flow through the engine to a torque level that will be available the moment you press the throttle. You can modulate the hit of torque by how fast you press the throttle when you want to go as to not shock the driveline or break traction.
The issue with holding it on launch is heating the turbos, but there are time limits and temperature cut offs if you hold it too long.
You could also apply a small amount of brake at this time also which will help load the driveline and then you won't need as much ignition cut/retard which will share the load of wasting the energy to spool the turbos.
There are lots of settings to control the anti lag and you can set it up how you like!
Darren.
