M1 GPR Boost Control
Can the ecu be in multiple boost limit states at once? If so, what is the order of the structure and how does the calculation?
From the firmware help, it states the following
"Boost limit values are a percentage of the range between Boost Activate and Boost Aim Main."
If I was to have various boost limits in each of the following, does it combine the calculate the total % of all of the active states?
1. Driver Engine Boost Limit via a Rotary Switch
2. Fuel Composition Boost Limit
3. Coolant Temp Boost Limit
4. Inlet Air Temp Boost Limit
