M150 ECU The Right Choice? Enough Space?
Hi
I have a 1997 Auto/Tiptronic Toyota Supra (JZA80) VVTi Twin Turbo.
I would like to retain the sequential OEM turbo setup (http://mkiv.com/93-98-twin-turbo-faqs-2/#turbosystem1) but refine the way it works.
Also run a true DBW set-up (http://www.garagewhifbitz.co.uk/index.p ... rsion.html) as the current OEM throttle uses a clutch based system with gearing from a DC motor which is alot slower than a modern equivalent and extremely expensive to replace should it go wrong.
Also allow the ECU to control the Auto/Tiptronic gearbox to eliminate the dangerous kick-down that these Supras are known for. I understand the OEM box will need to be scoped to enable the ECU to do this correctly and that it will be costly but are there things I can do to help get the data required?
I would also like to run the following sensors;
• Bosch Knock Sensor
• MAC 3-Port Boost Control Solenoid (35A-AAA-DDBA-1BA)
• 3 Bar Map Sensor
• Inconel EGT Probe
• Lambda Cable With NTK Sensor
• Oil Temperature Sensor (Engine)
• Air Temperature Sensor (VVTi)
• Oil Pressure Sensor
• Fuel Pressure Sensor
I hope the ECU can do all the above but am unsure if it will have enough space for everything I wish to add.
Future plans include a single turbo conversion should the OEM turbos die and a replacement pair are difficult to source. I will still run the standard 6 injector set-up versus running 12.
Thanks for reading and sorry for the long first post.
• 3 Bar Map Sensor
• Inconel EGT Probe
