M150 Inconsistent timing in Honda cbr600rr
Hello, I am with a formula SAE team and we are having an issue where the timing is advancing with rpm.
The engine will start and run and reaches cycle lock. However, When I have the ecu in "timing mode" set at 0 degrees the timing will change drastically (30+ degrees) with rpm using a timing light.
I believe it is an issue with the magnetic sync sensor on the cam. But I can not figure out how to do any sort of ref sync capture using m1 tune.
Any suggestions or Ideas would be helpful.
