Re-scaling the Fuel composition sensor.
Postby DentGuy on Mon Jun 06, 2016 3:30 am
Hello this is my first post in this forum.
I am new to the M1 platform and so far im really liking it!!
One question I have is about scaling the Fuel Composition sensor to reflect actual ethanol content. I have the Flex strategy setup as gasoline being primary fuel and E85 being my alternative fuel. Obviously the fuel composition number is a reflection of how far in between each fuel you are (ex: 0% is 100% gasoline and 100% is 100% E85).
My question is can I re-scale the Fuel Composition sensor readout to be a minimum of 10% and a maximum of 85% so its a direct reflection of ethanol content? I would then re-scale all flex tables.
Thank you
Bob
DentGuy
Re: Re-scaling the Fuel composition sensor.
Postby DentGuy on Sun Jun 12, 2016 4:26 am
So I was thinking about it and if I use 100% ethanol as my alternative fuel setting then my fuel composition should reflect actual ethanol content.
If for any reason my thought process is incorrect i'm all ears.
DentGuy
