Motec M130 Throttle body Faults
Hello everyone, I have a project engine which happen to be a Toyota 1FZ-Fe that has been turbocharged. I have installed Motec M130 on the engine and the engine runs great except the Issue that I have with fault coming up regarding the throttle body that is holding the engine from being tuned for idel! If I turn idel control on the engine will stay in Idel mode no matter what throttle or engine rpm its on so in order to run the engine the idel control has to be off!
I have looked for every setting regarding throttle and all seems set correctly which is driving me crazy. I hope some of you gyz can tell me the mistake or issue I am having which will make my life a lot easier searching for this issue.
I am attaching a log file of my engine running
your help is appreciated..
