CAN Address Conflict with Prior Version Keypads
I have wired into my setup two of the prior versions of the keypads that have pre-set CAN addresses for both the buttons and the LEDs. Unfortunately, these are the same pre-set addresses used by my M190 for transmitting various channels from the M190 that I need, resulting in a conflict on the CAN bus. I see only two solutions:
1. Send the old keypads into Motec for reprogramming and sell the converter box that changes the CAN bus rate; or
2. Change the pre-set addresses for the M190 in M1 Build.
The problem with the former is it requires a complete rewiring of my keypads and primary CAN bus, costs money, and renders the converter box useless. The problem with the latter is that the July 2015 version of the GPR package I am running is not available in the form of an M1 Build project and, thus, the package code cannot currently be modified to suit.
Can anyone divine a tertium quid or am I saddled with the foregoing alternatives?
--Peter
--Peter
