Button 1 - Launch
- Arms either Stationary & Rolling Launch depending on conditions & cycles through 3 trim levels
- LED's indicate off or which trim level is Armed
Button 2 - Traction
- Arms the traction control & cycles through 3 trim levels
- LED's indicate off or which trim level is selected
Button 3 - Your Button?
- Could be anything
- Button can be momentary, latching, or four position.
Button 4 & 8 - Cruise
- Completely stand alone cruise control functionality (requires a DBW throttle)
- LED's indicate Active of Fault
Button 5 - Boost
- Selects 4 individual 3-Axis Boost Aim tables
- LED's indicate the currently selected table
Button 6 - Nitrous
- Arms 3 cumulative stages of Nitrous
- LED's indicate which stages are armed
Button 7 - Rev Match (H Pattern Box)
- Activates a DBW rev match system for H Pattern transmissions
- Similar Nissan 370Z functionality
Aside from the above Keypad features the package also includes:
Flex Fuel
- Fuel Content & Temp on a single input from a GM Sensor
- Fully Integrated into all fuel properties, not just a trim table.
Standard 5V lambda support
- Keep your existing wideband gauge/controller
- Integrated into all lambda functions
Improved Tacho Support
- Allows tach output to be 12V instead of Ground.
Please feel free to comment on any of the functions as well as the use of the final button!
For anyone interested that already has a development license we have already tested these functions extensively on development platforms and currently have them available. For everyone else hopefully I'll have this buttoned up in the next week or so!
