mk e wrote:mk e wrote:Or maybe it doesn't matter and the system is setup so the logging rate IS the sampling rate?
The sample rates are set in Build so that's not the case. If you look at the project your package is based on in build you can see the maximum sample rate. You could also change the sample rate if you had a development license.
There may be a way in Tune to look up the sample rate of each channel but I haven't noticed it yet. I'll take a look through next time im in the software. It would certainly make sense that it would tell you right in the log setup screen but from memory I don't think it does.
