M1 + Older SDL ... Communication?
I have a M130 powering my car successfully from a license builder. He is very busy so I thought I would reach out to see if MoTeC engineers could lead me in the right direction as I would like to wrap this up before performing some custom display mount work.
I have an older SDL backlight model that I have set up in the car. The unit powers up and communicates with the CPU via US. CAN bus is also connected as my M1 is showing no CAN faults as it was originally.
Now, I only have (2) sensors hooked up (Digital inputs 27/28 for independent wheel speed on the driver's side; M1 is handling the passenger side) and wanted some insight how to get key parameters (tach, vehicle speed, gear, engine temp, oil pressure, lambda and ethanol%)displaying on the SDL from the M130.
Is there any simple procedure to do so?
I can be directly contacted at doug.pelsor@gmail.com
DP
DP
