M130 Setup: Using AV inputs for 2-wire temp sensors
I am using M130 in my car and have added additional temp sensors for logging power steering fluid temp and multiples intake temps (pre and post IC ). AT3 is currently feeding the pre-IC, but the car needs to referece the Post IC for tuning.
Right now, the power input for each sensor is being fed by Sensor 5V B and then input to the ECU via AV7 and AV8. I was instructed to install a 1k ohm pull-up resistor on each sensor in order to make these temp sensors work on the AV inputs.
If this is correct base do my wiring, where is the best place to place these? Near the ECU or near the connector of the sensor?
What must be changed to registe in the ECU properly?
DP
DP
