M1 & Wifi
M1 & Wifi
Postby Jakob on Tue Aug 12, 2014 5:47 am
is it possible to connect the M1 to an Wifi access point and the tune the ECU wireless?
Thanks for any info
Jakob
Jakob
Re: M1 & Wifi
Postby mstech on Tue Aug 12, 2014 10:10 am
Yes, it can be done, just make sure that the access point supports IPv6 and that you can get a reliable signal from it.
mstech
Re: M1 & Wifi
Postby Russ on Thu Sep 18, 2014 8:29 am
Can anyone elaborate on what is required and how you do this please?
https://t.me/pump_upp
Russ
Re: M1 & Wifi
Postby esaatetesta on Tue Sep 23, 2014 2:00 am
I have been using Wi-Fi for several months now and it works fine. I can make you an adapter or give instructions how to make one yourself, just send me a PM.
Esa
See my M1 install at etesta.com
esaatetesta
Re: M1 & Wifi
Postby AJSG on Fri Sep 26, 2014 7:50 pm
I've tried subscribing at etesta.com but the communication area is still inaccessible. Also I have a few wireless access point lying about, it would be most helpful if you had the time to tell us how to set it up.
Thanks.
Andrew.
AJSG
Re: M1 & Wifi
Postby esaatetesta on Wed Oct 08, 2014 11:34 am
Sorry about the problems you are experiencing. You get the email from clicking the info... part and it should reveal the address which is "info at etesta.com". (This is to avoid spam)
Here's an article how I've done it: http://etesta.com/etesta-products/motec ... wi-fi.html, there are several ways how to do it.
Esa
esaatetesta
Re: M1 & Wifi
Postby AJSG on Sat Oct 11, 2014 3:13 am
So basically you are simply wiring a WiFi range extender. At the end of the article you mention installing an application. Do you mean the M1 Tune software? Or is there something spoecific you need to do on the receiving PC/Laptop.
Thanks,
Andrew.
AJSG
Re: M1 & Wifi
Postby Russ on Sat Oct 18, 2014 9:29 am
Thanks Esa, works really well :)
Russ
Re: M1 & Wifi
Postby gary@apt on Sun Nov 16, 2014 7:00 am
what about bluetooth module, i know others are using one
gary@apt
Re: M1 & Wifi
Postby David Ferguson on Mon Nov 17, 2014 5:16 am
Bluetooth is much slower than Ethernet (and even WiFi).
