Running Port and DI injectors on M182 using IGN outputs.
Postby incontrolsteve on Wed Nov 27, 2013 2:49 am
Can I run saturated injectors on an M182's LS IGN outputs? Running 8 x DI injectors in cylinder and 8 saturated injectors in port to get power at full speed, with remaining 4 IGN outputs running 8 coils, wasted spark, engine is even fire so ok there. So effectively running Hi-Lo injection with port and in cylinder locations.
Steve
incontrolsteve
Re: Running Port and DI injectors on M182 using IGN outputs.
Postby incontrolsteve on Tue Dec 03, 2013 10:29 pm
All sorted on this one. As long as injectors are 16 Ohm, I can use the spare IGN outputs to drive 'normal' port injectors for split fuelling.
incontrolsteve
Users browsing this forum: Google [Bot] and 16 guests
