M130 using E888 PWM outputs
Re: M130 using E888 PWM outputs
Postby picasso on Fri Apr 14, 2023 5:07 pm
Thanks for reply Dean.
I'll probably also have to install additional wiring for the battery positive and negative supply to the M130 as I don't expect the currrent wiring to have sufficient wire size to also power the additional solenoids.
Any suggestion to wire gauge to use here?
Rolf
picasso
Postby Stephen Dean on Fri Apr 14, 2023 5:12 pm
Hi Rolf,
18G for the grounds and Power supply. The Solenoids should be switched low side in the M1 so they will need a switched 12V+ supply (preferably from the same source as the M1) to power them.
