by David Ferguson on Thu Feb 02, 2023 7:58 am
You can test individual injectors using M1 Tune, without needing to run the engine. Look at the Initial Setup->Injectors worksheet. You should find a Test Output pane, where you set a test RPM (typically 1000 or 2000 RPM). Make sure the fuel pump is disconnected, set the first cylinder to test, and change Engine Output Test to Fuel Primary, when you press the "Q" key, it will change to the next cylinder, and switch to "Disabled" when it reaches the last cylinder.
Typically I do this test to confirm the configuration matches the wiring -- so Cylinder 1 is really Cylinder 1, not some other Cylinder.
You may want to switch to the worksheet Diagnostics->Fuel Outputs while the test is running to look for diagnostic errors.
