TurboSmart E-WG Motec M150
Re: TurboSmart E-WG Motec M150
Postby PQatPIT on Sat May 15, 2021 12:07 am
Do You have a driver stage unit between M150 outputs and actual wastegate motor? Maybe Motec DHB unit?
PQatPIT
Postby Stephen Dean on Fri Jul 09, 2021 5:54 pm
These units can be driven using a DHB to control the motor, the normal HB outputs do not have the current capacity (unless the operation of the gate is slowed down greatly) to drive this motor.
Postby karel021 on Sun Nov 07, 2021 6:29 am
SDean wrote:Hi,
Hey any chance there will be a second boostservo to choose from ? or any other good way to setup 2 of these?
karel021
Postby NathanB on Sun Nov 07, 2021 9:01 pm
karel021 wrote:
SDean wrote:Hi,
Hey any chance there will be a second boost servo to choose from ? or any other good way to setup 2 of these?
At the moment, there is no timeline to add a boost servo bank 2 option to any packages that do not currently support it. However, in place of using a MoTeC DHB, you could use a turbosmart Black box, which is intended to drive 2 boost servos on single output, which will suit parallel twin turbo applications.
Postby karel021 on Sun Nov 28, 2021 7:33 am
NathanB wrote:
karel021 wrote:
SDean wrote:Hi,
Gotcha will look into it.
karel021
Postby ZT-R on Fri Feb 10, 2023 2:00 am
ability to control 2 gates yet? I'm a big single with 2 of them on split manifold.
ZT-R
Postby NathanB on Fri Feb 10, 2023 8:39 am
ZT-R wrote:ability to control 2 gates yet? I'm a big single with 2 of them on split manifold.
GPRP-Pro Supports 2 banks of boost servo.
Users browsing this forum: Bing [Bot] and 2 guests
