Difference between GPR and GPR Drag packages?
Postby CraigComet on Mon Feb 02, 2026 11:54 pm
When I try to compare the GPR and GPR Drag packages, it seems as though the Drag package has improved resolution for tuning and sensors, more sensor inputs, better boost control , launch control, and significantly more traction control / torque management options compared to the GPR licence.
The only thing the GPR licence seems to offer that the GPR Drag doesn't, is cruise control.
Am I missing anything? If there is so much extra functionality on the Drag package for the exact same purchase price as the GPR, why doesn't everyone just buy the Drag package?
Thanks.
CraigComet
Re: Difference between GPR and GPR Drag packages?
Postby David Ferguson on Tue Feb 03, 2026 11:50 am
How do you know they don't?
When I look at the GPR Drag firmware, I see cruise control, but no Bosch ABS support. Older version of coolant pump control (without polarity and drive), no switch support for aux outputs, no pit speed switch... I quit looking.
Suffice it to say they are different, and your MoTeC dealer can help you select the right firmware package for your needs.
