M130 3uz engine
M130 3uz engine
Postby najm on Wed Jan 29, 2025 4:25 pm
I have a problem that the Engine is working at 4 cylinders
And the other 4 is not working.
Anyone have correct timming spark for 3uz.
najm
Re: M130 3uz engine
Postby Stephen Dean on Wed Jan 29, 2025 4:54 pm
From the information that I have found, the firing order of the 3UZ engine is 1, 8, 4, 3, 6, 5, 7, 2. This gives the angles as:
Cyl 2 = 630°
Cyl 3 = 270°
Cyl 4 = 180°
Cyl 5 = 450°
Cyl 6 = 360°
Cyl 7 = 540°
Cyl 8 = 90°
The Engine TDC Setup Wizard Firing Order Setup calculator in GP Lite will also generate these numbers and populate the table.
I would also check that the Engine Cylinders parameter has been set to 8.
Re: M130 3uz engine
Postby najm on Thu Jan 30, 2025 5:18 pm
Thank you so much
Now the car is working
najm
Re: M130 3uz engine
Postby najm on Thu Jan 30, 2025 6:55 pm
How much volt i put in
Engine speed pin threshold
And
Engine synchronisation pin threshold
najm
Re: M130 3uz engine
Postby Stephen Dean on Thu Mar 13, 2025 11:09 am
For magnetic sensors that looks correct, you would need to do an Input Capture to confirm the values.
Users browsing this forum: No registered users and 33 guests
