M130/M150 PINOUT EVO8
Postby godrift on Sun Aug 04, 2024 8:50 am
i need help with matching file of m130 & m150 with mitsubishi evo8 ecu 4 pin socket
i need to build adapter between evo8 4 pin socket to m130 ecu
godrift
Re: M130/M150 PINOUT EVO8
Postby David Ferguson on Sun Aug 04, 2024 9:34 am
Do you have documentation on your wiring? My preferred method is to create the M1 config package, then wire the engine to match the config. If while wiring I find something that needs to be moved, I change it in the M1 package at the same time.
Usually a factory workshop manual with wiring diagrams is needed to understand what the pins connect to and how they function.
Postby godrift on Sun Aug 04, 2024 9:51 am
IHAVE prepared an excel file with evo8 pinout and m130 pinout for matching.
i was looking here if someone did it already just in case i did a mistake.
David Ferguson wrote:Do you have documentation on your wiring? My preferred method is to create the M1 config package, then wire the engine to match the config. If while wiring I find something that needs to be moved, I change it in the M1 package at the same time.
godrift
Users browsing this forum: Bing [Bot] and 8 guests
