Hi all
No I have some more AV inputs...the dumb questions continue!
I saw from another post that the M1 samples barometric pressure from the MAP sensor on startup. Does it do the same if you don't have a MAP sensor but do have a airbox pressure sensor?
If not, does a barometric pressure add anything on a TPS based GPA tune with an airbox pressure sensor?
Thanks in advance
