Hi David
Thanks for you assistance, the Dash does display the wheel speed correctly, the block of 4 11's are the individual wheels and the 11 middle bottom is the speed from the gearbox sensor, speeds track perfect 0-150Kmph.
This file is the CAN sniff of this being sent to M150 when I took the picture of the dash, its doing ;
00 0A 00 0A 00 0A 00 0B
https://drive.google.com/file/d/1j1KGA7 ... sp=sharingThis is the Subaru bus doing a run to ~40Kmph and back down, 513 is wheel speeds ;
https://drive.google.com/file/d/1lKDm65 ... sp=sharingThis is deciphered in excel, same math as being used in Dash ;
https://docs.google.com/spreadsheets/d/ ... ue&sd=true The Subaru can data is the "2nd bit * 256 + first bit", then * 0.055555 to get Kmph, which is possibly backwards or different from what's normally expected !?
05 01 05 02 05 03 05 04 would be FL-15Kmph, FR-28.7Kmph, RL-42.9Kmph, RR-57.1Kmph
So I got the CAN resource wrong, I thought CAN 0 was bus 0, and CAN 1 was bus 1 !! anyway setting wheel speed to CAN 0 Offset 0 no longer shows red box with CAN TIMEOUT and an error, but it does state can timeout in diagnostic, and there isn't any speeds coming through !
M150 log file, not that it shows much, can't see how to log can data !?
https://drive.google.com/file/d/1LagEc5 ... sp=sharing
