Subaru STI 2016 M150 with CAN Keypad
Postby XCL08 on Sun Mar 17, 2024 9:32 am
Hello
I have a 2016 model Subaru WRX STI, running Motec M150 ECU, I have added the CAN Keypad, to control a couple things, launch control maps ect...
I would like to know if there is a way to turn on/off the cooling fans with the keypad, had a look around and could not find anything, I was hoping under the pit switch option there would be something to do with fans
apart from modifying the tune on a track day to keep fans on, is this possible?
Is this simply workbook related, so if its not in the original file it can't be added?
Thanks!
XCL08
Re: Subaru STI 2016 M150 with CAN Keypad
Postby Stephen Dean on Mon Mar 18, 2024 11:38 am
Which Firmware are you running? If you are not sure, the Serial number of the M150 will let me look it up for you.
Postby XCL08 on Mon Mar 18, 2024 11:46 am
Serial - 7479
Firmware - 01.00.0005
I have been told by previous workshop not to update the ECU firmware as this might cause issues with the tune?
Regards,
Andrew
XCL08
Postby Stephen Dean on Mon Mar 18, 2024 12:07 pm
Hi Andrew,
As this has a Powertune Australia Partner Package installed, you will need to speak to them for this question.
