by Aquila on Fri Aug 26, 2022 2:42 pm
Thanks for your reply
Front-wheel speed sensors are mounted on hubs and it is set to rear-wheel drive type.
Front-wheel circumference 1.950, pitch threshold 50% and time out 1000.0ms
I am not sure why the Wheel speed front final drive ratio was included in the set-up.
I note that in the settings the front-wheel drive ratio was different to the rear-wheel drive ratio.
I wonder what effect this would have had to traction control strategies.
I did notice a significant difference in front and rear wheel speeds when you would think they should be the same.
Regards,
