Idle problems
Idle problems
Postby iivvaann12 on Tue Jun 14, 2022 3:43 am
I'm having a problem with idle setup. Starts normally then dies after 10 sec. I have to give it a little throttle to start but I don't care it's a race car just want it to idle properly. Do you have any idea what could be wrong. Video and m1tune screenshots: https://drive.google.com/drive/folders/ ... sp=sharing
iivvaann12
Re: Idle problems
Postby Stephen Dean on Tue Jun 14, 2022 12:45 pm
Can you please upload the M1 Package and if you have it, logging of this occurring.
Looking at the minimal data provided, it looks like your Idle Mass Flow Feed Forward table has not bee configured, as the throttle is not moving to catch the idle speed drop. Your are also sitting on the advance limit for the Ignition Timing, so most of the control is being done by the Ignition. The engine should not be needing 25 degrees of timing to idle.
What is the Lambda doing as well? it may be that you do not have enough fuel in the Efficiency Table and it is running on the Crank Volume Compensation fuel for the first period of time that it is running for, and when this fuel runs out, then the mixture leans out and the engine stalls.
Re: Idle problems
Postby iivvaann12 on Tue Jun 14, 2022 1:54 pm
How do I make a log file? Sorry this is my first time using motec. Next time I will disable enable message so lambda works all the time. Also the throttle can not move. Idle can be controlled only with ignition. Where it said 6.7 that was actually 0 tps forgot to racalibrate I will sort it out tomorrow so everything is correct.
iivvaann12
Re: Idle problems
Postby iivvaann12 on Tue Jun 14, 2022 9:06 pm
I've added log and config file in the google drive link in the folder new
iivvaann12
Users browsing this forum: Google [Bot] and 24 guests
