M190 2 Knock Sensor as Differential Input
Postby Oliver_C on Wed Dec 29, 2021 4:32 am
Question:
Does sombody know, how to configurate the first
Knock Sensor as a Differential Input?
There is no Choice in the drop down Menu
to choose it?
Engine ECUM190
Package: GPRP(190) 1.11.018 July 2019
Knock Configuration
2 Differential Knock Inputs
Knock Sensor 1
Pin: C_51
Pin: C_44
Knock Sensor 2
Pin: C_43
Pin: C_49
When configurating the knock sensors,
only the second sensor is assigned as a differntial Sensor
Thank you in advance
With regards
Oliver
Oliver_C
Re: M190 2 Knock Sensor as Differential Input
Postby greenamex2 on Wed Dec 29, 2021 7:16 am
Oliver_C wrote:Question:
to choose it?
Engine ECUM190
Knock Configuration
Knock Sensor 1
Pin: C_51
Pin: C_44
Knock Sensor 2
Pin: C_43
Pin: C_49
With regards
Oliver
Set all the knock 1/2's to not in use and then differential knock 1 should then be available to select.
greenamex2
Postby Stephen Dean on Wed Dec 29, 2021 9:54 am
As Greenmax has said, you need to unallocate all of the Knock Input 1 Resources first to allow for the Differential Knock Input to be available.
Postby Oliver_C on Wed Dec 29, 2021 11:27 am
Thank you grenamex2 and SDean
Works fine now
With regards
Oliver
Oliver_C
