Boost aim off flex fuel levels
Postby DaveTS on Mon Sep 13, 2021 3:28 pm
Hi there,
I'm using an M142 with package: GM LLT 3.6 Hi Lo & firmware: GPR-DI(M142).
I want to adjust the aim boost levels based off the flexfuel sensor %ethanol. How do I achieve this?
Thanks for your time.
Cheers,
Dave
DaveTS
Re: Boost aim off flex fuel levels
Postby NathanB on Mon Sep 13, 2021 4:05 pm
Hi Dave,
You need to have the alternate fuel mode set to flex fuel, and have a boost output resource assigned to add all the boost control systems.
You are then looking for the 'fuel composition boost limit (%)" table.
This applies a scaling between the boost activate and boost aim main.
As this table has a maximum value of 100%, you set you boost aim table to suit your higher boost fuel (high ethanol content) and use the table to scale down for your lower octane fuel settings.
GPR - Flex boost limit help.PNG (25.03 KiB) Viewed 4840 times
GPR - Flex fuel boost limit.PNG (11.05 KiB) Viewed 4840 times
Postby DaveTS on Mon Sep 13, 2021 5:21 pm
Hi Nathan,
Excellent, thanks for this information, all sorted.
Cheers,
Dave
DaveTS
Postby Stephen Dean on Mon Sep 13, 2021 6:09 pm
More information on the Flex Fuel system operation in the M1 here
