Bosch Knock sensor wiring
Re: Bosch Knock sensor wiring
Postby jallenmd on Thu Feb 13, 2020 2:54 am
Thanks! I deduced that the four knock inputs would be used for differential knock wiring! Appreciate your response!
jallenmd
Postby ajwithers on Sun May 31, 2020 5:01 am
SDean wrote:Hi Andy,
In my experience, there is not a difference as to the way that the pins are wired for the two pin sensors, the three pin sensors have a shield pin as well, that needs to be connected to a 0V pin on the ECU.
The shielded cable has two as a minimum wires twisted together in a common sheath, and the shield is connected to a 0V pin on the ECU end only.
Sorry for being slow... but would like to clarify that when you say 0V you mean ECU ground / battery ground, or do you mean one of the Sensor 0v Grounds?
Thanks in advance,
Aaron
ajwithers
Postby chuckk on Mon Jun 01, 2020 2:19 am
ECU 0V means one of your sensor ground pins.
chuckk
Previous
