CAN error messages on M130
Postby picasso on Sat Apr 11, 2020 9:20 am
I get a lot of CAN error messages in the ECU Monitor View of the M1 Tune application.
The following items are connected to CAN port 1:
M130 ECU
C125 Dash
E888 Expansion unit
MoTeC 15 button keypad
LTCD Lambda to CAN module
Attached is a logfile of the CAN error messages. I`ll appreciate if anyone can help me identify the cause of these and hopefully sort the problem.
ECU Monitor Messages.docx
(22.13 KiB) Downloaded 733 times
picasso
Re: CAN error messages on M130
Postby David Ferguson on Sun Apr 12, 2020 10:45 am
Have you set ECU Transmit CAN Bus to 'CAN Bus 1'.
Check ECU Receive CAN bus too.
I believe the Geartronics code failed to check if a Valid CAN bus was selected before attempting to transmit their status.
You should report this to RDS or the developer of your package that is using the Geartronics firmware code.
