M1 ref/sync
M1 ref/sync
Postby lawnmower on Wed Nov 20, 2019 7:55 am
I’m new to the M1 series, is there a ref/sync function like with the x00 series ecu?
lawnmower
Re: M1 ref/sync
Postby Stephen Dean on Wed Nov 20, 2019 10:33 am
If you go to Online | Capture Inputs... you will find the capture function. The M1 version is improved on the RefSync Capture function in the Mx00 ECU's as it allows for the capture of the signals on all of the Universal Digital Inputs, and you have the data presented like i2 data.
Re: M1 ref/sync
Postby Marc on Mon Feb 03, 2020 3:45 am
I use capture input in M1 . I meet this problem. Please give me recommendation. Thanks.
Capture input error
Marc
Re: M1 ref/sync
Postby Stephen Dean on Tue Feb 04, 2020 10:24 am
Are you directly connected to the M1, or going through a network hub/switch?
This error is normally caused by excessive noise on the Ethernet network, causing a drop out of the message packets between the M1 and computer.
Can you try directly connecting to the M1 and doing the capture again thanks.
Users browsing this forum: No registered users and 48 guests
