I have a M150 GPR-Drag package that I'm going to be installing onto my R33 GTR. Am setting it up for staged sequential injectors and will be running on Flex Fuel. However my injectors are on a single fuel rail - 2 ports per runner with ID1050X and 1D1700X injectors.
I'm wondering about the fuel pressure side of things. Since I'll be running a fuel pressure sensor on the rail, having this feed to the primary fuel type, fuel pressure sensor input. Do I need to do anything to make sure the flex side of things being an alternate fuel, doesnt expect anything different with the fuel sensor not being enabled on it?
My thought is that I can set BOTH to the same base fuel pressure default value and it should correct via manifold pressure reference? even though the primary fuel will have a pressure sensor on it.
Thanks in advance
Chris
