Progressive Water Meth Control
Postby CarloL on Wed Mar 21, 2018 4:18 am
Hi
Is it possible to setup the M1 to progressively control the water meth injection as opposed getting a 3rd party controller?
incorporates a 3D PWM pump control table based off MAP and RPM,
Does the current GPR package still lack a driver switch for fuel volume trim? It has a driver switch option for fuel mixture aim (target AFR) main and trim, but nothing for fuel volume trim. Those with a development package can cure this pretty easily by some simple changes in M1 Build. Make a new switch ("Fuel Volume Trim Switch") with A/B functionality, then add that switch as a third axis to each individual Fuel Cylinder Trim table. Then link a driver switch to a digital input and connect that input to an output from the water meth setup so that when meth injection is on, the desired level of fuel volume trim is immediately applied rather than having to await closed loop control to get it there.
Do you have any Webinars on how to setup?
CarloL
Re: Progressive Water Meth Control
Postby Herrubermensch on Thu Mar 22, 2018 12:31 pm
Yes. See the thread by PEI330ci in this forum.
--Peter
Herrubermensch
Postby Blu302 on Sat May 19, 2018 4:10 pm
Run a standard pump with Injector dynamics stainless steel injectors, infinitely better control.
Blu302
Blu302
Users browsing this forum: Google [Bot] and 8 guests
