Ignition Cut using a Pin
Postby Brody on Fri Feb 02, 2018 1:55 pm
Right now I am cutting ignition through a gear shift but is there a way to set up ignition cut by referencing a pin? We want the ignition to cut when the pin sees 0v.
Brody
Re: Ignition Cut using a Pin
Postby David Ferguson on Mon Feb 12, 2018 4:40 am
What firmware package are you using and what are you trying to do? If you want the ignition cut only when the pin is 0V, you could you use a relay connected to your ignition power.
Otherwise -- what are the conditions you would want to terminate the ignition cut (wheel slip? Rev limit? timer? something else?)
