Setting Up Automatic Engine Kill
Postby Brody on Fri Feb 02, 2018 10:12 am
I'm wondering how to set up an automatic engine kill based on coolant temperature. Ideally setting this up around 220 degrees Fahrenheit. Is there a way to do this? Ideally killing ignition.
I see the warning mode coolant temperature warning setting(does this correspond with the coolant temperature warning maximum and minimum values?) and I'm not sure if this will just pop up as a warning on the screen or how it works. Thanks!
Brody
Re: Setting Up Automatic Engine Kill
Postby Stephen Dean on Fri Feb 02, 2018 11:05 am
If you use the Coolant Temperature Engine Speed Limit and set an engine speed limit of 1 for the temperature that you want the engine to be shutdown at, this will stop the engine.
Postby Brody on Fri Feb 02, 2018 1:41 pm
Thanks!!
Brody
Postby Brody on Fri Feb 02, 2018 1:52 pm
SDean wrote:Hi,
So Coolant Temperature Engine Speed Limit will reference the Coolant Temperature Warning Maximum for when to activate?
Brody
Postby Stephen Dean on Fri Feb 02, 2018 2:31 pm
No,
The warnings are separate to this, You setup a table with the Engine Coolant Temp as the scale, and you can then gradually reduce the speed limit as the engine gets hotter, until it gets to a point that the limit stalls the engine.
You can also use the Coolant Temperature Warning Maximum for this, but it is not as gradual in its activation.
Postby Brody on Sat Feb 03, 2018 3:48 am
Perfect, hows this look?
Coolant Temp vs RPM.PNG (69.48 KiB) Viewed 8890 times
Brody
