Data log problems
Data log problems
Postby Q8.BOOST on Sat Jan 13, 2018 12:10 pm
I have Toyota 86 Engine Swap package M150 I cannot add or remove Any channels in data log.
Q8.BOOST
Re: Data log problems
Postby Stephen Dean on Mon Jan 15, 2018 8:55 am
This sounds like you have Level 1 (Diagnostics only) logging on the M1, if you can provide me with the serial number of the M150 I can confirm this.
With Level 1 Logging, there is a fixed set of channels allocated to each Package when it is build, this is not changeable at the user level. These channels have been chosen to provide the required information to do diagnostic support of the Package.
Postby Q8.BOOST on Tue Jan 16, 2018 7:48 am
Hi
serial number of the M150 4105 With Level 1 Data Logging .
Q8.BOOST
