idle to high
idle to high
Postby nwwil on Tue Aug 29, 2017 12:36 am
i can not get my car to idle any lower than 2000 rpm, useing a ford falcon turbo fbw and m150
nwwil
Re: idle too high
Postby David Ferguson on Tue Aug 29, 2017 2:52 am
Is this a new problem, or a new installation?
So many questions... -- could you post your configuration and a log from the engine running?
Last edited by David Ferguson on Tue Aug 29, 2017 9:05 am, edited 1 time in total.
Re: idle to high
Postby nwwil on Tue Aug 29, 2017 3:45 am
a new insulation
nwwil
Re: idle too high
Postby David Ferguson on Tue Aug 29, 2017 9:03 am
Things that control whether the idle system is active:
Do you have Idle Mode enabled (Tune->Engine Systems->Idle Aim Idle Setup Panel)?
What are the values in the Idle Aim Main table?
What is the value of Idle Activate Engine Speed Margin?
What is the value of Idle Activate Throttle Pedal Threshold?
Things that control the Throttle Aim:
What is the Throttle Position when the engine is idling at 2000 RPM?
What is the value of Idle Actuator Throttle Aim?
What does the table Idle Mass Flow Feed Forward look like?
What are the values for Idle Mass Flow Proportional Gain, and all the Idle Mass Flow Integral XXX parameters.
Re: idle to high
Postby Stephen Dean on Tue Aug 29, 2017 9:05 am
As David said, Can you please post logging (preferred) or the M1 Package thanks.
Users browsing this forum: No registered users and 28 guests
