Hi all
Just ordered my PDM and trying to sort out the PDM template.
For the M130 'PDM switches' (eg using PDM Byte 0 Mask 01 to operate the "fuel pump relay"), what CAN address do these come out on?
Thanks in advance.
adrian wrote:They are sent on 0x11A, the details are in the M1 help under ECU Transmit
greenamex2 wrote:And it works!
Thanks for the help.
I even managed to get my MDD attached switches working with the PDM over CAN (slight kludge on the conversion from compound required).
Getting used to this CAN stuff, pretty simple once you get your head round it!
Next job, passing the MDD attached switches and rotaries to the M130 using the CDL-3 as a gateway.
Oh, and replace the ridiculously thin earth wire I fitted on the Bosch 044 years ago, definitely NOT 12-15 amp compatible!
